20 Most Recent
Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1 Questions & Answers
MAAX Saninova control panel
To find out more about replacement components, get in touch with MAAX directly or go to their website. You might be able to obtain the precise control panel you require from one of their authorized dealers or distributors.It will ensure you get an original one
Drain stuck in closed position
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain
HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that
jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Heater is not working on a brand new maax whirpool
If it requires 110/220 volts and was wired to a double breaker... check to see that the do-it-yourself electrician put the breaker in a location that will give 220 volts and not 2 parallel feeds on the same side of the panel. Or else turn the double breaker off and then on to reset it.
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM •
Plumbing
Answered
on Jan 17, 2024
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM •
Plumbing
Answered
on Oct 28, 2023
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM •
Plumbing
Answered
on Oct 19, 2023
