SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
SOURCE: Canon Ixus 850 IS
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
SOURCE: How do I set up a Canon G9 to display date and time on image.
Press the "play" button to view your photos. Then, press the "display" button until the time/date show up.
If you want them to print out the time and date on the photos, you do this in the "Print Settings" menu. Just press the "menu" button, and then go to the second tab that looks like a printer, then scroll all the way down to "Print Settings..." Press the "Func/Set" button, and then scroll down to where it says "Date: On/Off". Use the directional buttons to select "On" or "Off" and then press teh "Menu" button again.
SOURCE: my printer canon 4412 not
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
