We lost power due to weather for 24 hours. Upon getting it back, our GE fridge controls won't work & fridge isnt cold/freezing. By controls I mean the digital temp control inside & the buttons on the outside-dispenser, light etc. Does it sound like we lost the main board?
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Sounds like a thermostat got damaged when the power surged when utilities were restored. Thermostats are usually behind the temperature controller. Hope I've helped. BB
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number
WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
First you need to turn the freezer temp control back on(That just turned the whole refrigerator off)
The water dispenser may have stopped due to line freezing inside the refrigerator.
The ticking could have been the the element for the defrost cycle or the starter on the compressor.
So,turn it back on,set the temp to a normal setting and if the ticking is still there,wait 30 minutes to see if it stops,If no ticking is there when you restart it,wait 24 hour and check the temp inside as well as the water and ice dispenser,If all work,It is a defrost issue.If so you will either need a defrost timer,defrost element,or defrost thermostat.
If the ticking is still there,You will need to replace the start/run capacitor.
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
