SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
SOURCE: Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
SOURCE: My washer makes a loud noise in the spin cycle.
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
The main center bearing is going bad that's why it is not wanting to spin as fast and is also making the loud noise when its spinning i.e. sounding like a jet engine firing up or metal grinding noise. I would not repair this very expensive cost around $300 to $600 to fix I would go buy a good quality used one or a new one sorry for the bad news but that's what it is I see 2 of these a week in my shop same problem but hope this helps.
