FixYa.com
Haier XQG50-11 Front Load All-in-One Washer / Dryer
All Products > Haier > Washing Machines
Problems with Haier XQG50-11 Front Load All-in-One Washer / Dryer?
Get a Replacement
Troubleshooting and Support
Solved Problems for Haier XQG50-11 Front Load All-in-One Washer / Dryer RSS Feed Post a New Problem
Dryer
Dryer still gets warm but not as hot as it used to. Takes forever to dry clothes. Clothes used to come out really warm...
1 Solution
the Drum turns, but no heat, is it ok?
the Drum turns, but no heat, is it ok? Different machine, same problem. I've switched out the timer, thermostat/fuse...
1 Solution
washing machine
the water is draining out as it comes in , it keeps coming out of the detergent dispenser and out of the drain spout
1 Solution
water is leaking out of detergent...
I just got this washer/dryer combo. First run went fine, went to do a second load and now water keeps pouring out of...
2 Solutions
Haier Washer M # XQG50-11
Sounds like main drum bearing is gone. What's involved to replace it? Is it an outer tub replacement?
1 Solution
Washing cycle doesn't sping
The Machine stop working, we called a "technician" and he discovered few loose bolts, one of them shorted the...
1 Solution
top load washer
my washer will not engage the spin cycle
Post a Solution
View All
Unsolved Support Problems
Unsolved Problems for Haier XQG50-11 Front Load All-in-One Washer / Dryer RSS Feed Post a New Problem
HAIER WASHING MACHINE
KEEPS STOPPING WHILE ITS WASHING SAYING ERROR 5.
Post a Solution
Need an on/off switch
Where can I get this part?
Post a Solution
replacement part not available
I checked with Haier on getting replacement of one of the caster release levers locate at the front of the unit near the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Washer TypeAll-in-One Washer / Dryer
Load TypeFront Load
Weight Capacity11 lb.
Volume Capacity2 cu/ ft
Wash
Wash Presets7 Wash Presets
Spin Speedsmax. 600 rpm
Water Levels3 Levels
Temperature LevelsAutomatic
Washing MethodDrum
Extra SettingsHeavy Duty
Convenience
Additional FeaturesQuiet Operation
Control FeaturesDial Controls
DispensersFabric Softener Dispencer · Bleach Dispenser · Detergent Dispenser
Other Features
Exterior ColorWhite
Tub Material (List)Stainless Steel
Dimensions
Overall Depth21.56 in.
Overall Height33.75 in.
Overall Width (Display)23.88 in.
Haier Contact Information
Main support number1-877-337-3639
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
