Apparition du code d'erreur E000007_0000 dans le display bloquant le fonctionnement que faire?
SOURCE: probleme de fonctionnement du copieur,rapporter le
Le niveau blanc normal était not detected correctement en balayant
plaque blanche.
Lampe d'exposition défectueuse
Stabilisateur de lampe défectueux
Connecteur de lampe d'exposition défectueux
Plaque blanche normale encrassée
Miroir de balayeur ou lentille de balayeur hors de
position ou encrassé
SBU défectueux
Exposure lamp error
The standard white level was not detected properly when scanning the
white plate.
Exposure lamp defective
Lamp stabilizer defective
Exposure lamp connector defective
Standard white plate dirty
Scanner mirror or scanner lens out of
position or dirty
SBU defective
SOURCE: CODE ERREUR F1 00 QUE FAUT IL FAIRE ?
go into service mode (program interrupt clear interrupt)
enter simulation 26 sub 1 (option setup)
change to no finisher
CA to exit, and you're all set
SOURCE: plus moyen d'imprimer a partir
@claudezevart - C'est trop longtemps que je parle ou ecrire en francais, alors ma response en anglais...
My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers.
SOURCE: MON PHOTOCOPIEUR AFFICHE LE CODE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
SOURCE: Je viens de reparer une
Welcome to FixYa!
- colors are not the good ones
- ink is too liquid and flowes on the paper
Please click the link below and follow the step by step instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01078264&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3204785
Please also check if you are using the correct ink cartridge. Replacing the ink cartridge will also solve your problem.
Thank you for using FixYa.
Have a great day.
Jas247
