Canon PIXMA MG2520 Inkjet All-in-One Printer 28773460 Logo
T
Therese Quirion Posted on Aug 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the scan button and how do I start it?
Willie Mondo
Level 2:
Sergeant:
  • Expert 313 Answers
  • Posted on Sep 09, 2014
Willie Mondo
Expert
Level 2:
Sergeant:
Answers
313
Questions
Helped
64975
Points
704
Try this steps:
1. Load the document in your printer/ copier/scanner
2. On your computer, click on start (the windows logo button)
3. From the pop-up menu, click on Devices and Printers
4. From the window that opens, right-click on the printer/ scanner you loaded the document and click on the options for scan. (Make sure it is checked as the default printer)
5. A dialogue box will pop up options for you to choose and scan your document. It will be saved to a folder in the documents My Scans. Does this help?
I havea mx310 but have lost the manual - how do i set up to scan photos?
You can download your manual from this site:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Solution: Setting scan methods for the button (Windows) - MX310
Scanning using the Operation Panel
You can scan documents using the operation panel.
Important
bullet.gifDo not disconnect or connect the USB cable while the machine is in use.
bullet.gifIn Windows XP, the program selection dialog box may open when you press the Color Start or Black Start button on the machine for the first time. In that case, select MP Navigator EX, then select Always use this program for this action and click 'OK'. From the next time, MP Navigator EX will start automatically regardless of the selected scan mode.
arrow.gifSelecting a Response to Commands from the Operation Panel
1. Place the document face-down on the platen.
2. Press the Scan button on the machine.
The machine enters Scan Mode.
3. Press the Color Start or Black Start button on the machine.
MP Navigator EX starts on the connected computer. Scan documents on the platen or ADF (Auto Document Feeder) using MP Navigator EX.
Trust this is helpful.
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    1helpful
    The scan function won't work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated.
    the scan function won\'t work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated
    How do use the scan.
    Load the document on the platen glass or in the ADF.
    Press the [Scan] button on the machine.
    The machine switches to Scan Mode
    Press the [Color Start] or [Black Start] button on the machine
    MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass or in the ADF using MP Navigator.
    3helpful
    3answers
    The language on my printer screen is spanish, I don't know how to change it to english
    follow this steps Go to Menu > Maintenance > Set Language & Country/Region > Press Start for English > hope this helps
    I want to scan a document to my computer
    have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
    Overview of the Basic Procedure
    This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
    Make sure the CX6600's power cord is plugged in.
    Place your materials on the document table.
    Start a TWAIN-compliant application.
    In the application, open EPSON Scan.
    Full Auto Mode:
    EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
    Home Mode or Professional Mode:
    Make settings to optimize images and click Scan.
    The scanned images are sent to the application.
    Save the scanned images in the application.
    Scanning / How to Scan
    Scanning an Image
    Turning on the CX6600
    Placing your materials on the document table
    Starting the software and scanning an image
    EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
    Note:
    You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
    Note for Macintosh users:
    Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
    Caution:
    Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
    Before turning on the CX6600, make sure it is connected to your computer.
    Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
    You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
    You can start EPSON Scan in the following ways.
    * Start EPSON Scan directly as a stand alone application
    * Start EPSON Scan from a TWAIN-compliant application
    This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
    Note; if you are using Windows 98:
    ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
    Start ArcSoft PhotoImpression.
    For Windows users:
    Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
    For Macintosh users:
    Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
    Click the Camera/Scanner button.
    Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
    Note for Windows XP users:
    Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
    EPSON Scan automatically previews the image, and recognizes the document source and type.
    If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
    After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
    EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
    Caution:
    Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
    Note:
    Be aware that clicking Cancel on this screen closes EPSON Scan.
    The scanned image is sent to ArcSoft PhotoImpression.
    Note:
    * Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
    * When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
    If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
    Can't scan a document
    Maybe it wants you to hit a start button in the computer program, to start the computer receiving the scan. Try to get an owners manual, sometimes there's one in the install cd.
    1helpful
    How do i scan a document?
    Place photo on glass platen, then got to START
    Start button, Canon Utilities, Solution Menu, Scan/import, photo/platen, then press big green button.
    THen have fun scanning it is fantastic
    1helpful
    Scanning
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
    Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
    2. Click New scan .
    3. Click File , and then click Scan .
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
    2. Click Paint .
    3. Click File , and then click From Scanner or Camera .
    4. Click Scan .
    Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
    1helpful
    2answers
    Remote control code
    Dish Netork does not have the code for Olevia
    but you can scan for the code using the infformation
    here
    Remote Code Power Scan
    If your brand is not listed, use the following procedure to scan through all codes.
    If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
    1. Turn ON the unit you want to program the remote to control.
    2. Press the Mode button on the remote until the appropriate mode light is flashes
    3. Press the Address button. The mode light will start flashing slowly.
    4. Press the Power button. The mode light will stop flashing and stay lit.
    5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
    6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
    7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
    8. Turn the device back ON by pressing the Power button.
    9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
    10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
    11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
    12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
    old marine
    old marine
    ZJ Limited
    ZJ Limited
