ERROR CODE 0000-0001 I TRIED TO CLEAR THE IT BUT WHEN SWITCHED ON THE SAME NUMBER APPEARED
SOURCE: E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
SOURCE: error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
