Front end loader
Hi Friend, thank you for allowing me to assist you!
Typically an error code E38 on your Frigidaire washer could mean a few things:
First see if the air trap is clogged. If it is, that is probably the most likely issue.
If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
To make sure it is not a false error code, reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best regards! - Z
SOURCE: whirlpool front loader error code
hi thanks for your question. i would check the pump remove the front panel 2 screws on the front panel at bottom remove you will see a big plastic nut in middle un screw but you will get water put a bucket under this nut pull out and clean . this will solve your problem thanks the appliance doc
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SOURCE: F-02 error code on whirlpool front loader duet
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
