20 Most Recent Frigidaire CWS3600AS Top Load Washer Questions & Answers
After 13 appliance years, your washer is a candidate for replacement.
Frigidaire... | Answered on Aug 08, 2017
I believe same as Kenmore you have to remove the top panel, first remove the 2 plastic pc.s from the side panel, then u will see on each side a screw that needs to be removed, then lift panel up and out of way, u will see 2 gold clips near the center that need to be preyed or popped out, then the whole cabinet will come forward and out. look under it and u should see the door switch and a couple screws holding it to lid panel remove them as well, then unscrew the ground screw to the harness usually a green wire connected to the frame.
Frigidaire... | Answered on Apr 01, 2015
The first thing that i would check is the belt. It tales more energy to spin than agitate
Frigidaire... | Answered on Feb 14, 2015
CHECK AND SEE IF THERE ARE SCREENS AT THE WATER VALVE IT MAY BE CLOGGED THERE
Frigidaire... | Answered on Sep 02, 2014
WAHSING MACHINE IS NOT DRAINING WATER
Frigidaire... | Answered on Jun 08, 2013
Hello Ruth Walker - From what you are describing it sounds like the tub seal is leaking. Typically, if so, the tub bearing is more than likely also bad or faulty. Repairing the seal and/or bearing may be a costly repair. I would strongly recommend contacting a local professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified tech through the manufacturer website.
Frigidaire... | Answered on Feb 27, 2013
(this pre-typed covers both hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Frigidaire... | Answered on Aug 15, 2011
Usually when this occurs the lid switch has failed, even though it may seem ok
The lid switch is a safety device for the spin cycle. When it breaks the washer will
still agitate and not spin out. Hope this helps.
Frigidaire... | Answered on Jun 26, 2011
IT seems as though you might have a Motor problem or a damage belt.
Frigidaire... | Answered on Jun 02, 2011
Yes without it your washer will not go into spin cycle
Frigidaire... | Answered on Mar 28, 2011
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Frigidaire... | Answered on Feb 18, 2011
Frigidaire CWS3600AS Top Load Washer Logo
94 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
cold water trickling into washer cause
  • Washing Machines
