The paper comes out but it only copy halfway. The drum and toner is brand new, the spacer is also new. I always clean the machine but I did not overhaul it. The machine is already on second hand. That's all the detail I know. I hope you can help me, if you want to ask more questions to solve the problem, it is really appreciated. Thank you! Good day!
SOURCE: how can I solve the problem E000 on canon ir1600
hello,you have a problem with the thermistor that check the temperature of the fixing unit ,must change the fixing unit and than must do a clear all on service mode.
SOURCE: canon mf 6550 copy no print out its came out empty page
We had the same problem with our mf6550 printing blank pages after we changed the toner cartridge. I called the support desk today and they said it is the shutter. They told me to remove the toner cartridge and then (without a cartridge in) close the door briskly. Then open the door, install the cartridge and again close the door briskly. It worked! He said it may be a permanent fix or it may act up again. He also said I could take it to a service center to have it fixed permanently. The service desk # is 1-800-828-4040. They can tell you where the nearest service center is. Good luck.
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
