Take it to a qualified repair shop, unless you know about C.A.N - controller area network - serial data communication network between modules . U1900 -20 - ic states that one of the 8 or 10 or more modules on your vehicle has stopped talking .
U1900
CAN Communication Bus Fault-Receive Error
RCM
REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 .
U1900
Occupant Classification Sensor
U1900
SJB
U1900
DVD Player
U1900
Audio Control Module (with Navigation)
U1900
U1900
SDARS
U1900
Retractable Running Board Module
U1900
CAN Communication Bus Fault-Recieve Error
ABS Module
U1900
Parking Aid Module
U1900
4WD Control Module
U1900
Instrument Cluster
U1900
CAN Communication BUS Fault - Receiver Error
DSM
F10 is runaway oven temperature. It can be caused by a temperate sensor or the control board. Most likely its the temperature sensor. First unplug the oven. Then remove the back cover panel. The temperate sensor is located near the top to the right. You can test the sensor if you have a multimeter. Unplug the sensor, set your multimeter to ohms, check resistance between the wires. At room temperate (75 degrees) it should not be less than 1000 ohms or more than 1300 ohms. Below is a amazon link to the sensor for your range. Amazon com Frigidaire 316490003 Temperature Sensor Silver Home Improvement
How to use the solutions in this document
To resolve the issue, try each solution
in this document, and then use the steps in this section to print a
self-test report. This step determines if the product hardware functions
correctly. When you have resolved the issue, and the product
successfully prints a self-test report, there is no need to continue
troubleshooting.
Print a self-test page
Follow these steps to print a self-test report.
Load plain paper in the paper tray.
Press the Power button (
) to turn on the product.
Press and hold the Power button (
Press the Resume button (
) four times. The self-test page prints.
IMPORTANT
: Try to print a self-test report after every solution even if the solution resolves the issue.
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a chkdsk /r or a repair reinstall of xp might resolve the issue. to resolve issue...
Error Code
Error Message
1000-0141 or 2000-0141
No Drive Detected
1000-0142 or 2000-0142
Drive Self Test Failed Status Byte=XXh
1000-0143 or 2000-0143
Drive Smart Read Command Failed
1000-0144 or 2000-0144
No Support for Drive Self Test
Error Code
Error Message
1000-0145 or 2000-0145
Timeout waiting for Drive Self Test to complete
1000-0146 or 2000-0146
1000-0147 or 2000-0147
Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s)
1000-0148 or 2000-0148
IDE ERROR: status (x) (s)
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
