I think there are two line one green and one light red. is there anything I can do to fix it or I need to put it to sleep? The monitor is a dell 2001fp.
I also have a Dell 2001FP where i have a yellow vertical stripe on the left side and about a inch and a half to the right is a red verticle stripe on the flat panel screen. Is the monitor bad?? Tired of seeing this.I also have a Dell 2001FP where i have a yellow vertical stripe on the left side and about a inch and a half to the right is a red verticle stripe on the flat panel screen. Is the monitor bad?? Tired of seeing this.
In addition to my stripe problem as i just remembered,is that the red stripe sometimes will fade in and out and sometimes won't be there at all until i'm on the computer for a while. More info,better results.Thx. In addition to my stripe problem as i just remembered,is that the red stripe sometimes will fade in and out and sometimes won't be there at all until i'm on the computer for a while. More info,better results.Thx.
You can't post conmments that contain an email address.
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
sounds like the tube cot a burn in the face of the tube . Unfortantly theres no fix foirthis except to chenge the tube. You are also going to need to have the horizontal sweep section checked out on the red tube or it will happenaagain . I have seen in the past a simple cold solder connection on the red yplk plug has caused this problem .. It is not a repair an amature or handi person can or should attempt to do Please seek out a trained tech to assist you in this repair. Good Luck
