our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any...
(More)
our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any suggestions on how to fix?
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and...
(More)
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and both I/C chips and TV turned on and stayed on for about 5 minutes and at convergence set up on TV, screen started bouncing and TV again shut down. I then replaced all the back resistors and TV turned on and again shut down with 1 blink. I replaced remaining resistors on front I/C with no luck. SD Tech had me to unsoder I/C and TV turns on and stays on. He had me to install two more new I/C. Still no luck. I have replaced all resistors and convergence chips two times. with chips sodered TV can be turned on with light box on table with remote but shuts down in a few seconds. When I unsoder the I/C chips TV will turn on and stay on until I turn it off with remote. This is the same thing that happened with first set of I/C chips. SD Tech has been very helpful.Can He or anyone else help solve this problem.
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a...
(More)
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a newer version to run on both XP and Vista, and probably Windows 7.
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
