Dell UltraSharp 1708FP 17" LCD Flat Panel Monitor Logo
Posted on Mar 29, 2009
How do you unlock dell monitor to turn down brightness
Need it unlocked
  • Anonymous May 18, 2009
    were the hell is menu
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on Mar 29, 2009
Anonymous
Contributor
Level 1:
Answers
13
Questions
0
Helped
17501
Points
78
 all you should have to do to unlock the controls is press and hold the Menu button for about 10-15 seconds. That should unlock all of the controls.
  • 1 more comment
  • lpbthe2nd Jan 19, 2011
    What is the menu button????
  • binoblaine05 Jul 21, 2011
    There are 5 buttons on the side. At the very bottom is the power button. The menu button is right above the power button.
  • Anonymous Apr 27, 2013
    That worked for me, thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
10001
Points
Throw it in the bin. use a mac
  • Anonymous Aug 02, 2013
    Actually..one is a monitor and the other is a computer supposedly, so if you threw it in the bin, you would still be without a monitor. Throw the mac in a bin and get a computer that will actually run some software.
2answers
My DELL LCD MONITOR E178FP is locked, when i press menu button, on screen it displays lock symbol
Zaheer khan,
To unlock the monitor controls and get rid of the lock you can press and hold the menu button in for 20 seconds. You can also try the information listed in the link below.
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
2answers
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
My monitor says the soud is locked, how can I unlock it!
Is it a dell monitor? If so I bet the power switch is pushed in?
1helpful
I keep showing a padlock when i try to adjust my E172FPt monitor brightness
Press and hold the menu button for 15 seconds or until the locked padlock icon changes to an unlock padlock. When it becomes unlocked, you can adjust your monitor. Hope this helps you.
26helpful
2answers
Dell P2210 menu is locked, how do I unlock it?
You have to hold down the top and bottom buttons at the same time for around 10-15 seconds and it will eventually display an unlock icon and you are back in business..
2helpful
2answers
Have a 16" dell flat screen monitior. The display are very dim,and make for hard viewing. Tried to push buttons on computer but a locked icon flashes up. Tried holding the buttons to unlock but did not...
You need to hold the menu button for 15 seconds until the lock icon changes to unlock. Then you should be able to adjust the brightness of the monitor, assuming that the backlight is working properly. Hope this helps you.
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
OSD LOCKED UNLOCKED Problem
it may be in demo mode, try presing "engine" and selecting normal.
Or press menu and select setup and scroll down to factory reset.
4helpful
2answers
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
1helpful
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
