I received a Hitachi 57SWX20B (57" HDTV) that has no picure or sound. The previous owner said...
(More)
I received a Hitachi 57SWX20B (57" HDTV) that has no picure or sound. The previous owner said when it first went out, he just wiggled the cable behind the TV and the picture reappeared. after a couple of times even that didn't help. Can you help me?
does not turn on. red light comes on for a second then you can hear it turn off again hitachi 57...
(More)
does not turn on. red light comes on for a second then you can hear it turn off again hitachi 57 swx20b
closed caption is on even though it is turned off. It is in spanish on some channels, english on...
(More)
closed caption is on even though it is turned off. It is in spanish on some channels, english on others and none on others. how do we turn it off?
I am looking at a Hitachi 57SWXZOB this week. Someone is selling this TV for $600. and he says it...
(More)
I am looking at a Hitachi 57SWXZOB this week. Someone is selling this TV for $600. and he says it is about 4-5 years old. Is this a good price? He says it works perfectly, he in converting the TV room to a baby's rooms so he has to get rid of the big monster of a TV.
Is there a web site I can scope out that gives the basic information about this model? Can I obtain an owner's manual on line for free?
What are the most frequent problems with this model and what does it cost to repair it ? Tess
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
