Hitachi 32fx49b, was watching tv when picture went out, still has sound and some picture. part of...
(More)
Hitachi 32fx49b, was watching tv when picture went out, still has sound and some picture. part of picture is in middle of tv
My Hitachi dinosaur television picture goes off and on for no reason. It goes to a complete black...
(More)
My Hitachi dinosaur television picture goes off and on for no reason. It goes to a complete black screen and then comes back on. It does this periodically. Do you have any ideas? Is this major? Should we just buy a new one. We love this one the picture is beautiful.. We thought it was our satellite system until we hooked up another television to the system.. So now we know it is our television. Oh, and the television shows it is on when the picture disappears. Their is no sound either..just a black screen. No error messages or anything like that. At times it does it when a commercial comes on, then comes back on after the commercial is over.
intermittent sound loss on both internal and external channels. The sound works for a while and then...
(More)
intermittent sound loss on both internal and external channels. The sound works for a while and then just cuts out. Sometimes it comes back when changing between sources; sometimes it does not return until the TV is shut down for an hour or so. Sound usually comes on when TV is first turned on - but not every time. The time before it disappears is random, but it always occurs eventually.
i have a hitachi dlp television model/serial 61swx10b The sound has slowly began to come and go at...
(More)
i have a hitachi dlp television model/serial 61swx10b The sound has slowly began to come and go at random, and at this point will not come back on at all. I only have a dvd player hooked up right now (no cable yet just moved into house) so cannot tell if it is dvd player, however, used to work just fine. only thing i have tried is switching audio inputs (with no luck) and also the sound from my dvd player works fine on my older tube television. If the speakers are blown out (if that is the problem), will a surround sound restore sound. Some insight would be fantastic, Thank you
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model...
(More)
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model #43fdx20b, How much is cost to repair?
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
