Dell UltraSharp 2001FP  20.1" LCD Monitor
Problems with Dell UltraSharp 2001FP 20.1" LCD Monitor?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Dell UltraSharp 2001FP (Gray) 20.1" LCD...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Dell UltraSharp 2001FP  20.1" LCD Monitor RSS Feed
View More Results for Dell UltraSharp 2001FP 20.1" LCD Monitor
Questions and Unsolved Support Problems
Unsolved Problems for Dell UltraSharp 2001FP  20.1" LCD Monitor RSS Feed
Answer
i have a dell 2001fp. it is locked and can not access it to change it to vga, however it has a fine... (More)
Answer
It occurs exactly as described. ~2" vertical band of pixels starts to randomize colors. Then... (More)
Answer
I copied homeboys` problem because he described my problem exactly, so we are obviously having the... (More)
Answer
Came on gradually - first couldn't get it to come on after going into auto sleep, but would come on... (More)
Answer
2001 FP DELL MONITOR HAS 4PIN POWER WHICH POSITIVE OR NIGATIVE
Answer
I have a dell ultrasharp 2001FP and when i put it on i get grey and blue lines then after couple... (More)
Answer
When the self test screen is up, there is a black bar that runs up the right side of the monitor... (More)
Find a Manual
Dell UltraSharp 2001FP 20.1" LCD Monitor Manuals & Guides
Tips & Tricks
(Post a New Tip)
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need... written by buddymc
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to... written by tbrat44
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection. To start unplug monitor from power and from computer and test computer with different monitor to find out if... written by ginko
Hannspree, I-inc, Hannsg
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the... written by worthy42
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Determine if you are having problems with your monitor or video card in...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor... written by BobbyR1234
Fix overheating ( goes Black ) problem.
I fixed the problem myself. I got tired of the loud fan behind it keeping it cool. Here is how I did it. Turn off the power and remove the monitor... written by Izzyreal
if there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is... written by dileep007
WikiManual
(Post a New Chapter)
How to Fix a Scratch on an LCD Screen
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air.... by wikihow
How to Fix a Stuck Pixel on an LCD Monitor
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction... by wikihow
How to Improve Image Quality on an LCD Monitor
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Dell UltraSharp 2001FP 20.1" LCD Monitor
Nationwide | (952)890-7770 | Website
Zkarlo.com provides discount and used laptop parts for... Read More
Featured Listing
Nationwide | 877-934-6198 | Website
Send your laptop to us and we will diagnose the pro... Read More
Featured Listing
Nationwide | 5138743306 | Website
We fix and repair laptop motherboard no video, no pow... Read More
Featured Listing
Nationwide | (877)729-0812 | Website
We connect to your computer over the Internet to qui... Read More
Featured Listing
Nationwide | 8664878724
Featured Listing
Nationwide | 8005882188
Featured Listing
Nationwide | 8004130133 | Website
We offer computer consulting services, hardware and... Read More
Nationwide | 407-284-1943 | Website
Affordable Laptop and Desktop Repair. We spe... Read More
Nationwide | 254-718-4042 | Website
we Service most consumer electronics. cb's twoway ham... Read More
Nationwide | 601-918-0222
I will connect to your Computer and repair the tro... Read More
Ratings for the Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Dell UltraSharp 2001FP 20.1" LCD Monitor
Write a review:
Rate this product:
Would you recommend the UltraSharp 2001FP (Gray) 20.1" LCD Monitor to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Dell UltraSharp 2001FP 20.1" LCD Monitor
Key Features
Size
20.1"
Contrast Ratio
400:1
Brightness
250 cd/m
Max. Resolution
1600 x 1200
Dot Pitch
0.25 mm
Monitor Type
Flat Panel LCD TFT (Active Matrix)
Viewable Picture Size
20.1 in.
Technical Features
Form Factor
Desktop
Regulatory Approval
Energy star
Digital Video Input Standard
DVI-D
Max. Viewing Angle - Horizontal
176
Max. Viewing Angle - Vertical
176
Resolutions supported
1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 1152 x 864 · 720 x 400
Dimensions
Depth
9.67 in.
Height
25 in.
Width
17.6 in.
Weight
18.72 lb.
Dell Contact Information
Main support number888-560-8324, 800-624-9896
Describe your problem:
Top Monitors Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
