Printer has not being used for over one year, . i plan to use it again.on my first re run,blk and yellow inks did nit print. Thus I proceeded to change to new catridges.Now printer goes thru the motions, but is not printing
This issue can be caused by several different reasons.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
SOURCE: printer goes through motion of printing but no ink
fir make sure you have loaded the ink cartridges correctly by removing the tape on the top and make sure it snaps in place. Once you have ensured that there is ink and properly seated. perform a nozzle test and check the colors, you should follow the instructions on the screen. if it still doesn't print correctly or at all I would then do a cleaning of the print heads. and then do another nozzle test if still not correct, then do a deep cleaning and another nozzle test. if after all of those things are completed and you still cannot print, then call manufacturer of printer and see about your services and or options.
SOURCE: Black ink not printing
Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
SOURCE: I have not used my printer in 3 years. I just put
the ink in the rest of the print mechanism is most likely dried up.
