Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdfCleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
ā¢ Characters are not printing completely.
ā¢ White dashes appear in graphics or printed text.
ā¢ Print is smudged or too dark.
ā¢ Colors on print jobs are faded or they differ from the colors on the
screen.
ā¢ Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
