Can the part with the 7 holes in come apart to be cleaned as it smells, i have tried cleaning it but to no avail it still smells sue
Hi Susan,
We'd strongly advise against attempting to disassemble the cyclone pack, as this is likely to snap the internal bin-base release rod, and can also reduce the performance of your machine.
If you're concerned about the smell from your machine, I'd encourage you to get in touch with us directly, by calling 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our advisors will be happy to run through some troubleshooting checks to make sure the smell is coming from the cyclone pack. They'll also be able to offer advice on the best way to resolve this issue without damaging your machine.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: Smells when in use. Have cleaned filter inside red canister, but that didn't help.
Vac up some carpet freshener this will help get the musty smell out. ,
SOURCE: Dyson makes smell
You need to replace the belts. When they are worn they put off a smell. Here is the belt you need:
Dyson DC14 Belt
SOURCE: How do you clean the Dyson dco7 cyclone top
Hi its Darran at Dyson.
We would not recommend that you take the cyclone top apart. This part is designed to be a sealed unit and taking it apart may affect ther performance of your machine ongoing.
If you are concerned with the performance of your machine, please follow the blockage procedure and filter washing instructions on our website in the support section at www.dyson.com or check your user guide.
If you do want to clear dust and debris from the cyclone, we recommend that you simply hold the cyclone top over a bin and bang the sides gently to remove any dust from the inside.
Kind regards
Darran
Dyson Customer Service
SOURCE: how do i clean my dyson root cyclone vacuum
believe it or not i would use a long paint brush with a opened bin linner,, to collect all the dust,,,
you can wash your blue filter in plain water and leave to dry as u would pots n pans on the side,,
when u have cleaned the area around the cyclone.. close your eyes and blow into the cyclone.. then use another large hoover to remove access dust and rubbish that was in the cyclone,
hope this helps reguards lee.
