SOURCE: Hoover Savvy runs but has a burning smell...
Could be that the motor went bad, or one of the circuit boards is bad. The brush roll motor is the likely suspect.
SOURCE: Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
SOURCE: My dyson dc14 has a strong burning smell
A DC 14 has two belts - one that connects the motor ourput to the clutch mechanism (the dial that lets you turn off the brush rotation completely is part of the clutch mechanism), and another that connects the clutch to the brush bar.
Unfortuneatley, the one that connects the motor to the clutch is hidden under a plastic cover so is very difficult to check.
With the machine running, and NOT in the upright position (i.e. as if you were vacuuming a floor), make sure the brush bar is actually rotating. If it isnt, you need to check both belts and the clutch. Due to the cover being held by three "Torx" screws, one of which is very difficult to get at, this isnt easy.
If the brush bar is rotating, then the burning is an indication the motor is about to fail. Motor replacement is possible depending how good your DIY skills are, and again you'll need "Torx" drivers to dismantle it. Website www.dysonmedic.com has some very good info.
SOURCE: sweeper smells
Several questions:
What does the smell seem to be? If rubber, check the belt and brushroll for free rotation. If a musty smell, check the bag, it may need replaced with a new paper bag. If it has an electrical smell, like hot insulation, then the motor needs checked.
SOURCE: Vacuum gives off a strange smell (stink) and sounds strange
Have you replaced the post motor filter? It could be time to do that.
Perhaps your cyclones are clogged as well. You can find steps to disassemble and clean your cyclone, pretty easy actually. Only 6 parts inside there and they only go together one way so you can't screw it up. Search google for dc14 cyclone disassembly and you'll probably find the video. I just did my DC17 and it took about an hour total to take apart, clean and then reassemble. You can also take the opportunity to wash all the parts and disinfect with a mild water bleach solution. That'll help with the smell.
I am betting though that your post motor and premotor filters are the blame for the smell.
I bought my DC 17 from some lady who used it to clean her cat's litter boxes. Cyclones were totally clogged after only 6 months. What do you expect from poop and wet kitty litter. She said it was junk and bought a $1500 Kirby in it's place. She's gonna have some new and interesting smells with that machine sucking up wet kitty litter.
