LG WM2455 Front Load Washer Logo
Michael Ross Posted on Apr 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer won't unlock
Anonymous
Level 3:
Guru:
  • Master 1,705 Answers
  • Posted on Apr 28, 2012
Anonymous
Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402840
Points
5112
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Lock on display wont power up
What is the make and model number?
May 24, 2013 • Dishwashers
2helpful
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.
Click this link for tips to reset the lock: Door lock
Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
1helpful
The washer was starting spin cycle. It stopped & started huming. The door won't unlock. It has water in it. unplugging hasn't changed anything.
If it has water in it it may not unlock the door, it depends on what type of door lock is fiited as it may be a pressure type. If you can get the outlet hose out and lower it below the level of the drum to drain the water that is in it then the door may open oncethe pressure is gone.
My washer is locked won't open
Will Not Unlock
• Press off. The motor control is not responding if it
takes 4 minutes to unlock. The motor control is
either bad or disconnected.
• Unplug and reconnect power cord. Wait 20 seconds
for machine to unlock.
• Check lid locked switch circuit. Circuit should be
closed at machine control.
• Check for loose electrical connections at lid lock and
at machine control board.
• Push lid closed to make sure nothing from inside is
pressing against it which may keep it from unlocking.
• If necessary, remove clothes by disconnecting power
to washer, and open top cover with a putty knife.Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
2000 model Hyundai lantra immobilizer won't start
un hook your battery for 15 minutes then retry to start
The display reads loc and the machine won't work
Typically to unlock the controls on a Duet washer what ya do is push and hold the END OF CYCLE BUTTON for 3 seconds and the control should unlock
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
5helpful
The door on the washer is locked and won't unlock. I have a load of towels in the washer, cannot get towels out. Please help me Thanks
HI - UNDER THE CORNER OF THE SOAP UNIT YOU WILL FIND A GREENISH YELLOW NYLON - PULL ON THAT TO UNLOCK THE DOOR.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
