Tip & How-To about Washing Machines
ACCESSING THE DRAIN PUMP ON A FRONT LOADER
Today I will be showing you how to drain & clean your Drain Filter on a Front Loading Washing Machine.
Be sure to unplug your machine, before doing anything beyond this point.
THE DRAIN FILTER COMPARTMENT
Most washing machines have a already accessible compartment for your convenience at the front of the machine.
Common compartments can be found here:
Compartments can be opened by any small flat object, insert it at the top and flip it out downwards.
DRAINING THE WATER
Ready a small bowl, and position under the drain filter compartment. Position towels by the compartment
You now need to drain the water, there should be a small pipe with either a plastic cork / small tap which you can open. Let it drain all the water to the bowl:
Not all Washing Machines have this pipe fitted, if that is your case, get some more towels, and a low dish for the next step.
CLEANING THE FILTER
Now the filter is the round compartment you can see, it is taken out by turning it anti-clockwise. Once loose, more water will be streaming out (a small amount, if drained adequately in the last step).
Once this filter is out, you can clean the filter cap, which should be out of the machine (In your hand, sir) - Wash it of under a running tap.
Insert your fingers into the Pump Compartment, and remove any gunk (coins, toothpicks, small stones etc), if you push your fingers in deep enough you will feel the drain pump's impeller, make sure this can be moved with no obstruction, by turning it with your fingertips.
Re-insert the filter, close the compartment and plug in your machine again.
It is recommended to clean your filter at least once a week, to avoid build-up that could harm your drain pump.
I hope you have been helped with this Tip.
JEDEMEYER
Washing Machines Logo
display is showing "oe", my card shows that it is a drain error, but I can't find my manual to see how to fix the problem.
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Aug 07, 2010 | LG Washing Machines
Washer does not spin. Tried to start cycle over
Thank You !!
Jul 26, 2010 | LG Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
18,806 people viewed this tip
Top Washing Machines Experts
