SOURCE: Canon IR210s copier
Are you sure you have the right toner??? It says it is for the IR-200-210 or dose it say IR-330 & IR- 400? If you look on the inside front door cover there are pictures showing how to install the toner, also there are pictures on the box the toner came in and also the display sceen will walk you through on how to replace the toner.. It slips in only one way and push down on it till it locks in then pull the blue tab till it displays "STOP" then push it back in and the push on the black part on the front of the developer unit to release the toner bottle and close the copier back up and lok the blue lever to the left and you are done. Good Luck
SOURCE: canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
SOURCE: Canon Copier 6025
The Waste Toner is located in the the drum unit it self. You need to remove the drum unit & on the top of the drum unit is a white or clear rectaular cap. You need to open it carefully and vac out the toner in side the unit. FYI if you are empting the waste toner the drum is just about worn out... Good Luck
SOURCE: How to remove drum scretch from Canon 6045 Copier
you cannot fix a line of a drum. If the drum is causing a line on copies you have to replace it. Any light or fingerprints can cause further problems. Look online or at your local canon dealer for the drum unit.
SOURCE: copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
