Question about Canon NP 6050 Copier
How to remove drum scretch from Canon 6045 Copier
How to remove drum scretch from Canon 6045 Copier Machine
Posted by raavndra143 on
Anonymous
  • 11 Answers
You cannot fix a line of a drum. If the drum is causing a line on copies you have to replace it. Any light or fingerprints can cause further problems. Look online or at your local canon dealer for the drum unit.
Posted on Oct 20, 2009
Anonymous
  • 541 Answers
Sorry you have to replace the drum. you can not buff it out or fill it in
Posted on Oct 12, 2009
HELLO Sir, How to fix error e019 in canon ir1018?
E019 means your waste tank is full. In iR1018/iR1020 series copier, waste tank is located at drum unit. First, remove the drum unit from the machine. Second, open the white plastic lid of the waste container. Third, drain the waste. Re-fit the plastic lid of the waste container and re-insert the drum.
Oct 06, 2014 | Canon IR1018J Black and White Copier
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Jul 25, 2012 | Canon NP 7130 Black and White Copier
Servis manual 6035
6035/6050/6545/6045 service manual
Aashish [email protected] com
In mail Address Convert Space ( ) to Dot (.)And Mail me To All Service Manual
Sep 22, 2011 | Canon NP 6035 Copier
I am using canon ir 400s copier machine the copier did not show any error but the copier it work but the printing time its did not printing
there may be problem with primary charging roller. to replace the primary charging roller, take out the drum unit, remove plastic cover, remove three screws of the shaft plate, take out the drum,detach primary charging roller from stand and replace .
Feb 11, 2011 | Canon imageRUNNER 400S Copier
Error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
May 19, 2010 | Canon ImageRunner 2020i Copier
We have an old 6025 canon copier that we have sold. Is there a harddrive or a chip in it that we can erase or remove to prevent any of our business data from being left on the machine?
This is an analog copier that does not store any form of company data. Any data that is on the machine is strictly limited to operating usage, such as job settings, etc.
There is no hard drive or memory that needs removing.
This copier was not networkable or able to scan and save documents. It used lights and mirrors to transfer an image to the drum and then onto paper. The drum is wiped every page. A similar example would be an old film camera. Once you throw away the film, there is no image remaining.
May 17, 2010 | Canon NP 6551 Black and White Copier
How to change the toner to my canon np 6045
There is a panel you open on the Right side of the keypanel.Insert the bottle upsidedown and hook in place slide the plastis handle of the hoper unit to the right and the toner will fall from the bottle inside the hopper unit.Close the hoper unit slide before removing the toner.
Dec 09, 2009 | Canon NP 6050 Copier
Np 6045 Canon photoopier drum scretch in the durm hwo to solve
Change the OPC drum and the drum cleaning blade.
Sep 27, 2009 | Canon NP 6050 Copier
Canon Copier MF 6530 stopped printing after a paper jam, everthing else works fine no error code just won't print. I have remove the cartridge shook it and still nothing. Do you have any suggestions?...
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
Apr 04, 2009 | Canon imageRUNNER 5570 Copier
Canon NP 6050 Copier Logo
327 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
