The washer was originally installed, using a non-GFI circut, renovation included installation of a GFI protected circut. Then the problem, the GFI was then switched out...new one installed, in case original braker was bad...same redults...turn on the machine, it goes thru the scan cycle aprox 20-30 seconds then trips the GFI...
SOURCE: GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at [email protected]
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
SOURCE: BAD LID SWITCH
This MANUAL shows how. What you must do is remove the front panel. It is kinda tricky. Use a thin blade to release clips between the top and front panel then tip the front panel towards you and lift it out yer way. Then you can remove the screws holding down the top and get to the switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My GE topload washer fills then starts to agitate
your washing machine is overload or its timer is not working properly
