GE WVSR1060A Top Load Washer Logo
Question about GE WVSR1060A Top Load Washer
GE top load Profile washer. Spin cycle not
GE top load Profile washer. Spin cycle not working. Does not agitate either. Still fills and drains. 2008 model
Posted by bartpaul on
D. Floyd Kolb
  • GE Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineGE top load Profile washer.  Spin cycle not - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machGE top load Profile washer. Spin cycle not - 2_bing.gifc="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
Serial # SD117482G
Most likely the control or timer. What is model #?
1helpful
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
1helpful
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Top GE Washing Machines Experts
Marvin
Marvin
Mike
David Shaub
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
