I have a GE freezer, model number FUF20DPARWH that blows a ground fault circuit breaker when it goes into the defrost cycle. The case is not "hot" when this occurs and it is plugged into a circuit that does not have a GFI breaker. It seems to work fine when plugged into a non-GFI protected circuit, although I have not yet been able to confirm that it actually defrosts when the cycle starts. Is this normal for this model? If not where is the problem and how do I fix it?
Ralph, the only way to be sure of what is going on is to check the amp draw of the freezer when it is in defrost. If the amp draw is in range ( listed on model/serial tag ) you may have a GFI that is weak.. if unit does not defrost there will be an ice buildup on the lower half of the back wall... But with unit tripping GFI it probably is defrosting............ Ken Hawk
Testimonial: "Thanks. As it turned out, the defrost heater had an internal short to its case near the neutral end of the heater element. It still defrosted OK. I guess the freezer case was not hot when plugged in to a non-gfi circuit and the gfi breaker had blown because the non-gfi circuit had a green wire connection that grounded the freezer case and kept it from getting hot. The main breaker did not blow apparently because the short in the heating element was so close to the neutral end of the element that excessive current did not flow."
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
SOURCE: Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
SOURCE: Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold
air around in the freezer and blow the cold air from the freezer into
the fresh food section, it also sucks the warm air from the fresh food
section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
SOURCE: Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
