20 Most Recent GE WR30X10093 Refrigerator Icemaker Kit Questions & Answers
Choked up pipelines ... Check inlet lines.
GE WR30X10093... | Answered on Oct 04, 2014
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
GE WR30X10093... | Answered on Jul 26, 2013
check the compressor if its running or not if not check its low pressure switch may be the unit is lack of refrigerant or if this one have a PC board change it maybe the old PC board is not functioning thats why the compressor is not running
GE WR30X10093... | Answered on Apr 21, 2013
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
GE WR30X10093... | Answered on Jul 05, 2012
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue.
your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
GE WR30X10093... | Answered on May 28, 2012
GE WR30X10093 Refrigerator Icemaker Kit Logo
24 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
just installed ge
  • Refrigerators
