NEC MT1075 Multimedia Projector Logo
Anonymous Posted on Apr 19, 2011
How you can fix blue light problem on NEC projector? Shahid
Anonymous
Level 2:
  • Expert 442 Answers
  • Posted on Apr 19, 2011
Anonymous
Expert
Level 2:
Answers
442
Questions
Helped
176984
Points
703
What does the blue light problem look like on the screen. is it all over the screen, or small dots, or a dim haze etc?
  • Sean S Apr 19, 2011
    blue dots on mine, left side, larger blue areas on the right side.
NEC WT610 Projector powers up and acts like normal, but will not project an image or the usual blue screen with menu functions. Bulb is fine and lights up, no error lights showing. It's as if it's stuck on...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
5helpful
Blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
NEC Lt240 prblem
Hi 80camaro
You could check in the Service Menu if your RGB is the same percentage and at the same run rate.
The run rate is normally 45-60 and the percentage on 50.
I would however recommend that you take it to a NEC agent to get it serviced.
If this doesn't fix it , then you will be looking at a new Mainboard.
Thanks for using Fixya and good luck.
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
