Question about NEC MultiSync LT280 LCD Projector
1. Click on the Menu button, either with the remote, or using the controls on the projector.
2. Use the Select control, scroll to the Setup tab at the bottom and click Enter.
3. Use the Select control, scroll to the Installation tab on top and click Enter.
4. Use the Select control. scroll down to Orientation and click Enter.
5. Use the Select control, choose the Front option that gives you the correct picture. (The Rear options are only used when projecting through a mirror)
6. Use the Select control to highlight OK, and click Enter.
Posted on Jan 21, 2011
SOURCE: upside down image on 51c
You need to go to the projectors menu and go to the advanced area.
From here, select ceiling.
You should be good to go.
Posted on Aug 23, 2008
SOURCE: nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Posted on Apr 10, 2008
SOURCE: upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Posted on Jan 11, 2010
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Posted on Apr 12, 2010
