20 Most Recent
NEC WT610 DLP Projector Questions & Answers
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings.
[Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Power light flashin orange, status
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is:
2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path.
3 cycles - the power unit is not working correctly.
4 cycles - the fans are not working correctly
5 cycles - lamp fails to light. Wait a full minute and then turn on again.
I have WT610 and I tried reset and holding 3D to
I am sorry, i didn't get the question completely. Which options are you trying to access?
Are you trying to clear the cornerstone screen?
If not, read page 107.
http://www.projectorcentral.com/pdf/projector_manual_2818.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6 red blinks
circuit problem,maybe the solution is byy cleaning by the unit
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
