SOURCE: PowerEdge 2600 does not boot up ?
you need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
SOURCE: Dell Poweredge 2650 - How do I disable RAC
If this is a security concern then there is nothing to be concerned about so long as you do not plug a network cable into the RAC.
Otherwise, if it is an add-in card just remove it.
If you can't remove it there should be a way of accessing it when the server starts up. You should be able to go into the configuration and disable its functions.
I hope this helps.
