Computers & Internet Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PE1850 Install Issue
I can not boot from an external USB DVD drive on a new 1850. The BIOS is set to boot from the USB drive (first in list). At the point were it should be booting from the USB drive, it says that the system has no OS installed and stops there. Am I missing something?
Thanks,
  • cmeadows900 Apr 02, 2009
    Thanks, but there is a bootable WinXP DVD in the DVD drive.
    Let me clarify, I have set the boot priority in the BIOS to boot from the USB DVDROM drive first. I do not have an external hard drive. I am trying to install the OS on the internal drive. Booting from USB is supported on the PE1850, but appears no to even try.
Anonymous
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Apr 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
258
Questions
0
Helped
115740
Points
926
Ya ! when you boot from usb drive and there is no win xp in the boot drive then how you would imagine that it detect OS....?
  • 1 more comment
  • Anonymous Apr 02, 2009
    so boot from dvd rom rather then hard disk....in bios priority...
    you can install xp in your external usb hard disk
  • Anonymous Apr 03, 2009
    REMEMBER, THIS GUIDE WILL DELETE ALL DATA FROM DRIVE C: AND PENDRIVE
    ( if you can't format your drive C:, install Windows Xp On Your
    Pen, then move all data needed using Pendrive or Network Area to the
    other PC )
    What do you need?
    1. Windows Xp installation disk
    2. Access to PC with working CD Cd-ROM DVD drive.
    3. This file solution.rar
    This guide is for people with basic knowledge of PC hardware and system software
    Let's start.
    1. Download solution.rar file
    2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
    3. Put your pendrive ( at least 1GB) into working PC USB port
    4. Go to the folder C:\Dos and run HpUSBformat.exe file
    - it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
    - set other options like on the image below and click start.
    - now you have a pendrive with bootable dos on it.
    5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
    - your pendrive should look like that
    6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
    7. Boot your laptop with pendrive ( if you have problems, just check your BIOS or try to access boot menu )
    8. Type sys d: and hit enter
    - if you see system transferred - you have luck, FAT32 filesystem on drive C:, you will not lose your data
    - go to step 11
    - if any problem apears go to step 8
    8. REMEMBER, you will loose all data from drive C:/
    9. Type format c:/q/s
    - accept and if it is formated go to step 11 ( you are lucky, you don't need to make partitions)
    - otherwise go to step 10
    10. Type fdisk and hit enter
    -create new partition ( after restart boot with pendrive in)
    -go to step 9 and back here :)
    -type pqmagic and set your new partition active ( physical drive 2, Advanced A, ste Active - S, are you sure - Y, Exit - X )
    11.Type nc and hit enter, and using Norton Commander, copy all files form pendrive to disk C: ( you can overwrite existing ones)
    12. Restart Laptop without pendrive in it ( it should start from harddrive)
    13. Type cd i386 and hit enter ( it will enter i386 folder)
    14 Type winnt and hit enter
    INSTALL WINDOWS :) ( REMEMBER, DURING INSTALLATION - KEEP EXISTING
    FILE SYSTEM - DO NOT FORMAT, YOU CAN CONVERT IT TO NTFS LATER )
    Boot from external drive or pendrive is same.....
    or try this
    Unlike Mac OS X, Windows XP is not designed to boot from external
    hard drives. Thus, getting XP to boot from an external drive to be used
    with your Intel Mac requires some work.
    MacRumors user mrichmon reports having installed Windows XP SP2 successfully on an external USB drive using his MacBook to perform the install.
    [edit]
    Steps
        Modify your Windows install CD to support booting from a USB drive. (Instructions on how to modify your Windows XP install CD)
        Remove the internal hard drive from the MacBook.
        Connect the external USB drive. Note that some users report
        that the Windows installation will abort with an error unless the USB
        port nearest to the power connector is used.
        Boot from the modified Windows install CD.
        Progress through the Windows install, creating partitions and
        formatting the partitions as you see fit. You may want to partition the
        drive under Mac OS X using a FireWire connection, since Disk Utility cannot always partition USB drives.
        Wait for the Windows install to finish.
        Reboot into Windows on the external drive.
        Install the Apple device drivers for Windows.
        Replace the internal drive.
    Note: Since a key step in this process is removing the internal
    drive, this process is best suited for MacBooks, since their hard
    drives are easily accessible. http://forum.onmac.net/showthread.php?t=..." target="_blank" rel="nofollow" >An alternative method for installation
    in which a few Windows files are stored on a small 6 MB (not GB)
    partition on the internal HD is available which does not require
    removal of the internal HD.
    After all of this you will be able to boot into Mac OS X. You
    will not be able to boot into Windows by holding down the option key
    when booting. Instead you will need to connect the USB drive to a
    running Mac OS X system, open the Startup Disk Preference Pane and
    select the Windows partition. Then when you reboot you will boot into
    Windows. To return to OS X you need to use the Windows Startup Disk
    control panel to select Mac OS X. Mac OS X will also boot if the USB
    drive is not connected.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
Toshiba a60 bios
Hi ahshan,
You need to enter the BIOS settings, enable USB boot, then disable all other booting devices, such as hard drive and network boot. This should force your PC to boot from your external DVD ROM.
Best wishes,
Graeme.
1850 dell monitor problem
try new cabels, reseat, diff monitor. the onboard video might be bad
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
1helpful
Hi, my Dell PowerEdge 1850 Server freeze at boot screen after print remote access controller detected. anyone ve any solution on it ?
I had exactly the same issue, its basically your iDrac card thats likely at fault. I simply removed mine and the server would boot as expected. If you require the iDrac then order a new card and this should solve your issue.
What cables do i need to connect my acer laptop to my asus netbook to boot the recovery dvd for the net book and how do i want the bios on netbook to be set thanks
usb cable and external usb dvd reader. it can be done with a thumb drive with a bit of work also.
There is a setting in bios for install, and you should make sure bios is set to boot from either external cd/dvd or thumb drive depending on how you are installing. once the installation is complete you should on next reboot change the bios setting from install to normal, otherwise the usb port will operate at 1 speed instead of 2 which is annoying.
Hello! Here is my problem; I have Gateway MX6426 laptop and CD drive went off. When I try to install Windows XP from external CD drive some problems occurred. I put CD in ext.CD drive,run clean...
Press F1, ie for Gateway to enter Bios settings.
Go to your BIOS MENU,
From "Boot options" set 1st boot to "removable drives" save the setting, ie if you are using an external CD/DVD or USB flash drive. If you are using an external CD/DVD Rom, ensure that the power supply to the external CD/DVD Rom drive is sufficient.
Try and reinstall the Operating System again.
Hope it helps, and good luck.
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
9helpful
3answers
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
