20 Most Recent Dell PowerEdge 2650 Server Questions & Answers
It might not be a driver. It might be the monitor. Try another monitor.
Dell PowerEdge... | Answered on Apr 14, 2018
download dell server assistant onto a cd... youll get a menu, follow the menu. you also need the server 2003 installation cd
Dell PowerEdge... | Answered on Aug 19, 2012
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Hello, Not sure what the media type is but I will assume you mean a tape drive as you are able to switch between write protect and writable. At the boot of the tape cartridge you should find a button that moves from side to side. You should be able to see "write" on side and when you move the switch you should see "Protect". If this is not the media form you are usings, repost with what type of media you are using. Good Luck.
Dell PowerEdge... | Answered on Feb 23, 2012
Be sure to check your cable connection both at the drives and the motherboard. You may have to swicth then out with known good cable. If you do use new cable and get the same results, you may have a bad hard drive. Also, after checking the cable connection, recheck your BIOS setting to make sure the system 'see' the hard drives.
Good Luck.
C2Solutions
Dell PowerEdge... | Answered on Oct 09, 2011
There could be many things that could cause your halt problem. From my experiencew ith servers the first thing I would do is try resetting your BIOS setting to default. Also, reset the jumpers to clear out the CMOS and retry your install.
Keep us posted. Good Luck
C2Solutions
Dell PowerEdge... | Answered on Jun 11, 2011
Try entering the BIOS (usually by hitting F2 or Delete during the boot up sequence) and looking under the boot menu for the USB drive. Some older systems cannot boot from USB. You might have improperly formatted the USB drive. What are you trying to boot into?
Dell PowerEdge... | Answered on Feb 28, 2011
try turning usb support on in the bios,if this doesnt work try reseting your bios this should return it to default,hit f2 as it restarts when you are in. hit alt e alt f it should beep everytime you do this,what this basically does is clears nvram, go to boot devices and see what you have available,exit and retry your boot device
Dell PowerEdge... | Answered on Feb 25, 2011
Hi Dell poweredge 2650 dosent support usb boot
try using a CD or DVD or floppy if you can get 1 big enuf
Dell PowerEdge... | Answered on Dec 27, 2010
how is the boot order set in the bios ?
try to set cd/dvd drive first
Hello, You should be able to get into the bios and reset within.
Failing that .... power off the unit. Disconnect the servers power supply cable. i.e. make sure it is not connected to mains power. remove the covers. on the motherboard is a cmos battery .... remove it. wait a few minutes for the cmos to drain.
perform the reverse of the above.
when you poweron ... the date time will need to be reset. cmos password should also be reset.
Dell PowerEdge... | Answered on Oct 13, 2010
Unfortunately, the 2650 cannot boot to USB devices. Try PXE if installing an OS.
Dell PowerEdge... | Answered on Aug 19, 2010
This can be done with hardware or software.
Hardware: find and remove the CMOS battery
Software: buy a bootable program that will allow you to remove the password
Dell PowerEdge... | Answered on Aug 18, 2010
you will need to download the RAID drivers from the Dell website
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R74082&SystemID=PWE_PNT_P3C_2450&os=WNT5&osl=en&deviceid=1374&devlib=0&typecnt=5&vercnt=7&formatcnt=2&fileid=126163 and load them onto a floppy drive.
Then when installing the server press F6 to install other drivers this will load the PEC drivers and W2k3 will then see your drives
Do not try to load the drivers from a USB as W2k3 is "preset" to only accept drivers from a floppy drive unlike WIndows server 2008
Hope this helps
Dell PowerEdge... | Answered on Jul 23, 2010
Yes, Server 2008 will install on the 2650 as long as you make sure you have enough RAM and hard drive space. Once you have Server 08 installed, you will have a to-do list to help with setting up hyper-v.
Good Luck
C2Solutions
Dell PowerEdge... | Answered on Mar 05, 2010
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Dell PowerEdge... | Answered on Feb 21, 2010
Hi there, as per your information, i can say that the device driver missing from your system. Just install the driver again & restart your System . Then try it.Thanks & waiting for your feedback.
Dell PowerEdge... | Answered on Feb 19, 2010
Process of elimination? I first thought it may be a power problem but I could not understand the LED flashing (It still maybe a power problem) If you can leave on charge for 4-5 hours more if you can make sure the light is not flashing (That is turn the laptop off at the power switch) Try turning on after being on charge for as long as you can If that does not work it may be the bios with the wrong setting or the Hard Drive is faulty (The more I think about it I think it may the the last issue) Try the other steps first the turn on holding the DELETE button it (I think that is the button to access the bios ) This with work if the Hard is Good or bad)
Dell PowerEdge... | Answered on Apr 22, 2009
Dell PowerEdge 2650 Server Logo
30 questions posted
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
install hyper v dell 2650
  • Computers & Internet
