Question about Dell PowerEdge 1800 Server
Flshing Red Light on Dell Poweredge 1800 Server
I Have a Dell Poweredge 1800 server and the Green Light on the front face has recently changed to a Red Flashing Light. Everthing appears to be running ok but is the red light telling me that there is a problem?
Anonymous
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Dell 1800 poweredge when I press the button does not start, I can see green light on one of the display. what cause not to boot up?
you might want to check the power supply unit first, as it is very common for them to burn out and not supply the correct power to start up the server..
the 2nd thing i would do, is do a visual inspection of the motherboard , looking for any traces of burns, if any are found, replace the server.
Jun 11, 2010 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Power edge loght is red and blinking
You should be able to see the reasons in the front panel, remove the front cover and you will see a small display with some information passing slowly. Sometimes is just the redundant power-supply that is disconnected.
Nov 25, 2009 | Dell PowerEdge 1800 Server
Flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Apr 29, 2009 | Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Blue light flashing
Someone has pushed the system identification button on the front of the server. If you push it again the light will be solid blue.
Dec 24, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
Nov 09, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1800 Server Logo
2,890 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
