20 Most Recent Dell PowerEdge T110 Server (GB/2GB) (bema42a) Questions & Answers
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Dell PowerEdge... | Answered on Mar 08, 2013
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Dell PowerEdge... | Answered on Mar 14, 2016
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
Dell PowerEdge... | Answered on Jun 14, 2015
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Dell PowerEdge... | Answered on Oct 01, 2014
www.hp.com/support
Dell PowerEdge... | Answered on Aug 18, 2014
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Dell PowerEdge... | Answered on Aug 08, 2014
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start.
Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot.
go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
Dell PowerEdge... | Answered on Jun 04, 2014
what is your server model? in most cases you can use the operating disc to format the server drives
Dell PowerEdge... | Answered on Apr 04, 2014
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell PowerEdge... | Answered on Mar 27, 2014
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
Dell PowerEdge... | Answered on Jan 09, 2014
Dell PowerEdge T110 Server (GB/2GB) (bema42a) Logo
4 questions posted
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
dell poweredge t110 server amber error
  • Computers & Internet
