20 Most Recent Dell PowerEdge 700 Server Questions & Answers
Should be in power management and look for last state.
Terry
Dell PowerEdge... | Answered on Jun 14, 2015
Unless only one 256-MB memory module is installed, the modules must be installed in identical pairs. If you want 512MB total, you will need to populate by using two identical 256MB modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
Dell PowerEdge... | Answered on May 30, 2012
change the boot sequence first priority to cd and next to harsddisk.....
Dell PowerEdge... | Answered on Feb 16, 2010
This usually means there is a problem with your keyboard connection at the mainboard end. If you keep getting this error and you can not use your input devices, you will need to replace the board.
Good Luck
C2Solutions
Dell PowerEdge... | Answered on Jan 25, 2010
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Dell PowerEdge... | Answered on Apr 13, 2008
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Dell PowerEdge... | Answered on Mar 14, 2016
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Dell PowerEdge... | Answered on Oct 01, 2014
www.hp.com/support
Dell PowerEdge... | Answered on Aug 18, 2014
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Dell PowerEdge... | Answered on Aug 08, 2014
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start.
Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot.
go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
Dell PowerEdge... | Answered on Jun 04, 2014
what is your server model? in most cases you can use the operating disc to format the server drives
Dell PowerEdge... | Answered on Apr 04, 2014
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell PowerEdge... | Answered on Mar 27, 2014
Dell PowerEdge 700 Server Logo
Popular Tags
12 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
constant beep poweredge 840 appears work
  • Computers & Internet
