Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Right i have new laptop have loaded up disk for printer, and when i click print on laptop it prints something else that i printed last time i used the printer. it is a bx300f thankyou
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on Feb 16, 2011
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270588
Points
3723
Check what is in your print queue before printing. If a document fails to print completely it may remain in the print queue even if you turn the laptop off.
Loaded print brand new black/yellow and cyan/magenta print heads and printer and HP Easy Care say I need to load cyan/magenta print head.
This issues looking printer head problem. check the following Steps for cleaning printer head :
  • Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
  • Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
  • Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
  • Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
  • Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
  • Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
My printer won't print.
click start click on run or the keyboard shortcut is the windows key and the letter r at the same time
a run box appears click the browse button
click my computer and select the disk drive the software cd is in. look for a folder that is titled util or utility, open it and open the ccc folder. from there select uninstall l3
make sure your usb cable is disconnected
click okay to run the uninstall... it will begin to remove the hp software and drivers. let the pc restart, upon restart run a disk clean up
once the disk clean up is completed re try the install with the usb cable still disconnected untill the sw advises you to connect the device.
that should install the drivers cleanly and you should be able to print and scan
2answers
Printer was working two weeks ago now i try to print it would not cut on
Make sure the printer is plugged in and turned on.
Make sure that printer is set to default.
go to control panel - click printers - make sure it has a right mark on it - if it doesnt, right click printer icon and choose set as default.
If it doesnt work, try uninstalling and reinstalling the printer driver.
You can uninstall the driver using the printer driver disk or from add/remove programs.
Hope it helps !
Thanks.
Can't print a complete print job without problems
There may just be some type of configuration issue going on if you don't have a drive installed in this printer. If there is no drive installed the printer drivers may be functioning as if there's one present which results in this error. I'm providing you with a few possible solutions as it is more difficult to pinpoint an issue when you don't have access to the device.
If it is a configuration issue you can try these steps:
1. Mopier mode should be disabled.
Right-click printer then click properties.
You should find a device settings tab...scroll down to mopier
mode and make sure it's disabled.
2. Printer Hard Disk should be disabled.
Go to the Device Settings tab...scroll down to Printer Hard Disk
3. If you had to disable one or both features then the very last thing that you want to do is try printing a multiple page document to see if this worked.
If you check these two settings and find that both the mopier mode and printer hard disk are disabled then you can try this:
Click this sentence to follow the link to HP's driver and software page for the 4600 series printers. Find your operating system in the list and click on it. This will bring you to the page with drivers, firmware, and additional software provided for your printer type. Try downloading the drivers (unless you have the installation CD) and reinstalling the printer. Also, make sure that you have the latest Service Pack installed for your operating system. If you're using Windows XP then the latest Service Pack is 3.
Hope this helps. I work with HP printers and sometimes I have to try more than one solution before I find the right fix.
Please share your experience by rating this solution and thanks for using Fixya.
Old printer lexmart x6100 not recognizing new laptop
On the bottom right of the screen you should see a printer icon. Click on it and it will open the driver queue. Click on the job that is not printing and then delete or cancel the print job.
Don
3helpful
3answers
NUMBER OF COPIES
If you cannot print more than 1 copy, click on...
Start -> Control Panel -> Printers -> Right click on HP 1320 printer icon -> Properties -> Device settings -> Disable mopier mode (last option)
This worked for an HP 1300, 1320 and as well as an HP P2015d using the HP 1320 driver.
2answers
Epson DX8450 not printing
are you using leopard os x? when you said you loaded the driver for the printer, did you use the disk that came with the printer?
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
There are stripes through the whole page of what I'm printing
Hi, its the print heads are clogged up, couple of things to try, head cleaning would be the first option, right click on your printer status program ie on the bottom right of the screen the small icon, and you should find maintenance or head cleaning, try doing this a few times, print something out see if any change, if still no success, change the ink cartridge, if still no success last try would be http://www.supermediastore.com/cleaning-cartridge.html its a head cleaning cartridge to try and clean the blocked print head, if none of the above work you would be better replacing the printer as epson charges £75 + vat to repair any printer, the last time i tried to buy print heads at trade they were about £48+vat & delivery and is really a nightmare to fit with epson,most new epson printers seem to only last about 15 months on average but its the amount of money you can save through using compatible ink, as we only sell epson printers ourselfs and this happens with 99% of returned printers..
Happy New Year
John
2answers
Printer not printing
Try unplugging it or pulling the power brick out of the back, wait a few seconds, plug it back in, and then turn it on. It might have something stuck in its memory.
k24674
ADMIN Andrew
ADMIN Andrew
