Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
If you're sure you're using enough soap, check that your hot water is connected and that you're using a hot-water wash (some dishwashers have a cold-water option, this will often give unsatisfactory results if washing greasy dishes - especially beef fat).
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine? You should be able to feel the heat. If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder. Could you try using a liquid soap once and see what happens? Be blessed.
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Using too much soap is worse than not using enough. Over time, soap scum will build up and plug the internal plumbing of the dishwasher. Often, there is simply not enough water in the dishwsher to be effective. The GE uses an electric solonoid which opens when it is time to drain. This item can get corroded and allows water to pump out when it is supposed to be washing. Also, it is possible you are not getting enough water because of supply problems. Disconnect the hot water line and check the flow of water and also the intake screen to see if it is plugged. If you have ample water after the a wash cycle has been running for several minutes, check the water timeperature. It should be around 120 degerrs F.
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
