SOURCE: blinking main menu of the monitor!
my viewsonic monitor (E70fSB) having a problem, the main menu (the one with the option of adjusting the position, zooming, color, size, etc.) of the monitor always pop-up. i can't fix it. i hope you can help me asap.
SOURCE: Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
SOURCE: benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
