20 Most Recent
MPC Computers AOC 7F 17" CRT Monitor Questions & Answers
There is power but no display
Your symptom is commonly caused by failure if the inverter circuit. It is made by Sampo. The inverter powers the backlights.
Replacing the inverter is the first step to resolve the problem.
I have prolem in samsung
send me detail on
[email protected]
1) if yours LED power on and display of window not giving then problem from cpu.
a. first replace yours RAM and check display.
b. then display cable and check display.
c. Install new Display card and check display, if not giving display it means motherboard have a problem
2) LED not giving power on then problem from monitor
a. replace monitor power cable and check display
b. monitor logic card have aproblem
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Screen went upsde down
What do you mean the screen went upside down? Have you moved the Taskbar to the top? If so, right-click on Taskbar, make sure it is not locked(not ticked at Lock the taskbar), then left click on an empty space of the taskbar holding down the mouse button and drag the taskbar around the edges to where you want it.
The screen is flickering continuously after
When you open up the monitor, there will be a main board on the bottom. Look at the solder joints and see if you can spot any that have hairline cracks in them. You may have to look at the different solder joints with a magnifying glass to spot them cause they might be hard to see.
When you find them, take the solder off by placing your solder wick on the solder joint and then put your soldering iron on top so it heats up the solder and it melts into the solder wick. After you do this then put fresh solder on the solder joint.
Do this with all solder points that you find cracks in them.
This should take care of the problem.
Ben
Panview 15" crt
yes first you open the monitor then take output of smps if present then turn the knob behind eht untill the brightness with picture will not come
Monitor not Display
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
SIR
I HAVE AN OLD LAPTOP
there is one possible way
1. remove hard drive from your laptop
2. plug your HDD into another laptop in anyway(usb or enclosure)
3. Make your HDD bootable with DOS mode
4. copy the new OS folder to your HDD
5. Put back your HDD to your old laptop then boot it with DOS
6. find the OS folder you copied, from there run setup your new OS.
My mpc laptop cant openn programs like facebook and yahoo
some countries block these sites. Try going via a free web proxy (google for one) and see if this makes any difference although i would not been too keen to put your username and passwords in while using a free proxy as they may not be secure. The issue you have could also be with your security levels being set a little too high on your browser. You could try donwloading an alternative browser like Opera, Chrome, Firefox etc...
How to avoid stress when over using computer
In today digital era, most are already used to use digital products such as computers... in our home office and others but most are having problems after several hours of prolong use or exposure to computer... here a few reminders...
* Keep a proper eye distance from your computer screen at least 12-14 inches
* Maintain proper posture especially back support
* Have a momentary break for every hours
* Use sufficient lighting in your working area
Tear down
Yes you can. You might use Sugru to re-attach the cover. http://www.sugru.com
