Try to remove your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset itself. When the printer turns on, reload the cartridges. If the error continues, one of the cartridges may have gone bad. In that case, please refer to this article on 1102 Error Message on the Lexmark P4300 Series All-In-One to determine the cause of the problem. You may contact Lexmark technical support for additional assistance. Thanks.
Remove the print cartridges, and close the cartridge carrier lids.
Disconnect the power cord from the electrical outlet.
Reconnect the power cord to the electrical outlet.
If the button is not lit, press .
Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
Reinsert the black (or photo) print cartridge.
If the error:
Reappears, replace the black (or photo) print cartridge with a new one.
Does not reappear, reinsert the color print cartridge.
If the error reappears, replace the color print cartridge with a new one.
