Since you can print, its confirmed that you have installed the printer driver.
If you have not installed the Canon scanner driver then
Please click on the following link and confirm if you have installed the Scanner driver
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#DriversAndSoftware
Select the Operating System (OS - Windows ) you have.
post which you should be able to use the scanner.
SOURCE: canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan. I tried it, and it works. Printing can be done wirelessly, but apparently not scanning!
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
SOURCE: Canon PIXMA MX310 printer user manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Here is the link all the downloads including the manual avvialable straight from canon.
Thanks and enjoy,
Lee
