This whirlpool should be very similar.
Check the image and see if this is the arrangement.
Electrically the white is common and the other tan/red strip cold
Brown hot water for the Whirlpool.
The second image is for the AAV7000AWW where the pink wire is hot water and the Purple is cold. In both cases the white is connected together and is common.
Perhaps you've tried, but check to see if your printer is printing color using the PS driver or the PCL driver. If you are using the PS driver the colors will not print correctly, but this is the best mode to print black and white since it will save your drum life and print faster.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter. In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it. Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Go to " Dell All in One centre"
Click on maintain/ Troubleshoot on top of the page.
Then click maintain or fix quality problems.
then choose the problem you have.
It should be sorted,
