Washing Machines Logo
Posted on Sep 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the lint filter located on my 703 smart drive washer? I am going to flush out the pipes etc with Washing Machine Magic. This product says "clean the lint filter before using their product
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Apr 21, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314822
Points
1478
4 Related Answers
Anonymous
  • 4 Answers
  • Posted on Sep 16, 2008
SOURCE: I have a washing machine
Hi Andrew,
Similar problem on my 701.
Unfortunately the dirt etc can now get through to the microswitch underneath which is part of the main circuit board. You can't replace just a switch and a new board is about $200.
Suggest you undo the 2 screws at the back of the whole plastic control panel and lift off.
This will expose the main circuit board in the blue plastic box. Carefully open the box and you can then inspect the "power" microswitch for damage.
If you're lucky just a clean up may work. If you know a hobby electronics friend, they might give it a more professional clean up.
After reassembling, try some sellotape or similar over the hole to stop future dirt.
Good luck. If this advice works, do me a favour in return and give a few dollars to your favourite charity.
DIY Eddie.
Anonymous
  • 145 Answers
  • Posted on Feb 28, 2009
SOURCE: lint filter
Hi Bob... You probably have a buildup of crud in the outer tub itself, or perhaps someone washed a rug and the backin has come off and is all in the outer tub and little by litter it is cloggin up the water pump. I would suggest that you pull the inner basket out of the machine and do a good cleaning of the machine. It's rather easy to remove that inner basket- you only need a phillips screw driver!
1. Pop out the two plastic white caps near the front/top (under the washer lid but on the top of the washer) and remove each screw.
2. Remove the agitator by popping the fabric softener cap out and simply reaching down in the center and unscrewing the white plastic "tee" nut that secures it to the agitator shaft and lift the agitator up and out.
3. Lift the machine's top up (it lifts up just like the lid does)
4. Unsnap the "tub collar" from the washer tub, (requires no tools!)
5. Grab ahold of that entire inner basket and lift it right up and out of the machine. (you may want a helper to hold the machine top back for you)
Now with that basket out, you can see what you need to do as far as any kind of build-up. You can wipe clean the inner plastic tub and remove any lint/rug backing/crud you see, and you can take that basket and clean it up in a laundry tub, of it is warmer where you live, take it outside and spray it down with a garden hose. The underside is probably going to filthy. The outer side of the inner tub is almost like a cheese grater, it might have some lint snagged in the holes. Just spray it down and clean everything up. Put it back together and you're good to go again.
It takes me about 10 minutes tops to pull the inner basket. Fisher Paykel's are very easy to work on.
Anonymous
  • Posted on Jun 20, 2009
SOURCE: Aqua Smart washer says, "clean cycle" need after 125 washes. How do I do that?
It's under the "lifestyle" section of the wash selection menu. It was called "Clean me" on my machine
Anonymous
  • Posted on Apr 18, 2010
SOURCE: Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
User manual says to check "magic filter" on my samsung wa48j7700aw/a2 if I have stains on clothes that were not there when they went in wash. Where is magic filter located?
For the Samsung washers with the magic filter lint trap, look in the washer tub for this filter. It should be a vertical section on one part of the tub wall in the lowest third of the tub. For an idea of the location and how to open the magic filter, see https://www.samsung.com/au/support/home-appliances/what-is-the-function-of-magic-filter-in-a-samsung-washing-machine/ .
I hope this helps.
4helpful
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
4helpful
I can't find the lint filter in my 4kg machine. Where is it?
washer/dryers do not have a lint filter.. Any lint is flushed down the drain.
I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the...
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Where is filter MW059
it has a Auto-lint Disposalsystem which means there is no filter to access ,,,,, if your having lint on your clothes, check to make sure the drain hose isn't kinked and no down in the drain pipe to far.
Lary
2helpful
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
3helpful
Solving my lint problem in washing machine
the lint filter is a large plastic part that is conected to the bottom of the tub. you have to take the tub out to clean the lint filter. i would suggest, before you try taking the tub out, going to sears,they seel a product called washer magic. its a cleaning powder for your washer. just follow the instructions on the jug it comes it. it works pretty good
Washing machine
motor is starting to wear out ,replace it .
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
