HP Photosmart 3210 Printer Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error/carriage jam , I have removed paper and carriages and repalaced them???
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Sep 23, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795452
Points
2925
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product
http://www.fixya.com/support/t6088190-hp_7400_displays
Anonymous
Level 2:
Scholar:
  • Expert 78 Answers
  • Posted on Sep 19, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
78
Questions
Helped
10810
Points
245
It is posible there is something inside the printer that the carriage it hanging on. If the carriages moves at all try watching very close to see if it snaggs on something. Also the sensor in printer get messed up pretty easy.
1helpful
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
1helpful
2answers
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
2answers
Continue to get clear carriage jam after opening door and clearing or moving the carriage in hp 4215xi
Click here for instructions on resolving carriage jams on the 4215xi. If you successfully complete these instructions and still have carriage jams, your printer likely needs service.
I am an HP employee. I do not represent HP on this site.
2helpful
3answers
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
4helpful
2answers
Stylus CX9400 Photo Printer: paper jammed inside printer...
2helpful
2answers
13helpful
4answers
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
2answers
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
2answers
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
k24674
Grand Canyon Tech
Grand Canyon Tech
