Find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
