20 Most Recent Phoenix Digital PD-397 Car Amp Questions & Answers
The light on top of the amp is on. But neither
should have fuses on the side of the amp or inside of it. check them
2/9/2011 10:30:25 PM • Phoenix Digital... • Answered on Feb 09, 2011
How do you get the board out on it in order to
there should be tiny screws on the bottom to take off the top of the casing in order to access the main board. From there I would check the solder joints with a magnifying lens.
6/18/2010 2:59:13 AM • Phoenix Digital... • Answered on Jun 18, 2010
What would be the best amp to push 2 kicker 15 L7s
find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
4/6/2010 9:05:26 AM • Phoenix Digital... • Answered on Apr 06, 2010
Not sure what model it is its the red one
be sure your wiring your speakers correctly, ecspecially if their dual voice coil woofers. Had the same problem.
9/23/2009 7:27:26 PM • Phoenix Digital... • Answered on Sep 23, 2009
SL. Radio turns on, but why is there no sound?
The Murano may have a separate amplifier that has a separate fuse.
8/5/2021 2:31:13 AM • Car Audio &... • Answered 13 hours ago
2answers
I am out of prison and want to download music but i need a unlock code so i dont have to go through jpay to download music
Hello, Eric - Since your prison issued player is from JPay, you will need to arrange with JPay to have it unlocked for your use outside of prison. It will not work outside of prison now that you are no longer incarcerated. I suggest you contact JPay directly and ask about the procedure for having your prison issued player unlocked: https://blog.jpay.com/contact-us/ I believe you will need to send your tablet to JPay to have it unlocked and returned to you with the downloads you purchased and added to the player while incarcerated. Best wishes.
7/30/2021 12:23:50 PM • Car Audio &... • Answered on Jul 30, 2021
Wiring diagram for model RM-W50SAM-K car stereo?
Contact the manufacturer/distributor directly to request the diagram.
7/28/2021 8:15:51 AM • Car Audio &... • Answered on Jul 28, 2021
Looking for an English user manual
Contact the manufacturer/distributor directly to request the manual.
7/28/2021 8:15:20 AM • Car Audio &... • Answered on Jul 28, 2021
5answers
Change language to english in dvd NDDN W56
please help me too i ve the same problem [email protected], thanks
7/23/2021 1:01:57 PM • Car Audio &... • Answered on Jul 23, 2021
Can't get the clock to appear after setting it
Time display is the default condition when the radio is turned off.
7/20/2021 5:02:47 PM • Car Audio &... • Answered on Jul 20, 2021
I have a sparkomatic modle 245, 8 pin need wire harness color code
Contact Sparkomatic directly with your request.
7/20/2021 8:04:51 AM • Car Audio &... • Answered on Jul 20, 2021
2answers
Can't get FM to work on my Seaworthy 2300 Marine radio. CD works fine.
is the unit new? do you know how your FM antenna is wired. are you trying to pickup signal 50 miles offshore? Do you get AM?
7/17/2021 1:43:59 AM • Car Audio &... • Answered on Jul 17, 2021
What is the white wire for on my reversing camera
What good is an ionizer?
7/12/2021 4:52:45 PM • Car Audio &... • Answered on Jul 12, 2021
11answers
NDDN-W56 car DVD player shows "PLease insert
check there...
http://www.gps-guru.com
7/9/2021 8:57:05 PM • Car Audio &... • Answered on Jul 09, 2021
Phoenix Digital PD-397 Car Amp Logo
7 questions posted
Top Phoenix Digital Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Phoenix Digital Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Phoenix Digital Car Audio & Video
Most Popular Question
light top amp but neither
  • Car Audio & Video
